Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Virtual Dyno Update
    Virtual Dyno Update
    Just FYI to everyone, Virtual Dyno has a new update that will take HPT 3.x info directly without changing any of the .CSV values. 20170703_054204.jpg
    May 2016
    1,134
    Awesome. Thanks for posting. I was just changing the headers a couple nights ago on exported CSVs.
    Sep 2010
    872
    Quote Originally Posted by Dev1360 View Post
    Never used it before but i downloaded it and it won't open .hpl files and any time I export to CSV and load up the file the lines is all over the place, doesnt seem to be a way to clip it so it only uses part of the data in the file
    Dec 2017
    767
    where can it be downloaded?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    tried 1.6.2 and it didn't work out so well.
    Oct 2016
    Poland
    1,743
    You need to log specifically for VD - one straight WOT, not 10 MB logs with everything in it
    It work just fine.
    HP Tuners Support
    (foff667)
    28,268
    It work just fine.
    What is it you need to be logging? that was a 5000-7200 pull in 3rd gear at the track which is 85-118mph. Doing that no the street isn't my intention. And I spin through the majority of 2nd gear on the street so would not give accurate results.
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    Just narrow the view on HPT and export on the view of the pull. It works fine if you have all of the correct data for the vehicle.
    Oct 2016
    Poland
    1,743
    You need better tires mate
    Theoretically you need RPM, TPS and TIME only.
    Quote Originally Posted by jsllc View Post
    +1
    HP Tuners Support
    (foff667)
    28,268
    I did this.
    Jan 2013
    Hawaii
    2,101
    When you export uncheck interpolate data. You may still have to modify the TPS data to make sure its all 100% and not 99.9% or it may say it doesnt see and WOT. Unchecking auto trim TPS in the settings may help as well.
    HP Tuners Support
    (foff667)
    28,268
    that definitely helped, still kinda wonky but eh, its free.
    How accurate are the #'s you get from that?
    2010 Camaro SS 781rwhp
    TKR Stage 4 CTSV 6L90
    Circle D 258mm 3400 3B Pro Series Multi Disk
    Kooks Ceramic LT's & full 3in exhaust
    TFS GenX 255's (Polished PAC .660's and Ti-Retainers)
    TSP VVT 3.2 cam
    Smith Bro's trunnion kit
    AEM X-Series OBDII Wideband Gauges
    FIC ID1300x Injectors
    ZL1 Fuel Pump
    DSX Flex Fuel Kit / Auxiliary Fuel Pump Kit
    MM Camaro 5 Wild
    Holley Tall LS Valve Covers
    NGK Iridium IX #7
    HP Tuners MPVI2+
    ProCharger D1X @ 13psi
    Oct 2016
    Poland
    1,743
    Quite close - from my experience within 5%.
    HP Tuners Support
    (foff667)
    28,268
    I'd be interested in the .csv file that produced this result, also is yours a manual or auto?
    Oct 2016
    Poland
    1,743
    Auto, N/A with lots of mods.
    Oct 2016
    Poland
    1,743
    Here, fixed:
    Mar 2014
    309
    I didn't glean much from this either. Just a bunch of garbage. I'll stick with some simple math using MAF lbs/min. It's just a "feel good" number anyway. How it does at the track is more important IMO. As it stands mid 10's with a N/A stock long block 2012 is really all I need.
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    I usually use the rough math based on the MAF lbs/min. However, I am now guessing as I have maxed out that PID, so it is a guess at this stage. My DD is a 2012 GT, stock block with probably too much boost LOL. When it warms up here, it is off to the dyno again to get some new numbers.
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    I don't use it to see what my "numbers" are. I couldn't really care less about those. But it does help compare between tune changes or modifications given the same stretch of road and gear. The calculator will use SAE figures to account for the differences in weather.
    For an example, I could change my VCT values make a pull, then load different values and make another pull on the same stretch of rural road. I would see the differences, especially when I tried to make bad changes and test to see if it would be different.
