i have an issue where idle is fine but as soon as it gets a speed signal above adaptive idle it revs to 1000rpm and spark is being removed to try lower it (not thru adaptive control) but the TPS locks at a minimum 9.8% where idle is normally around 5-6% and it also holds revs durin gear changes which is annoying and it also affects deceleration
manual trans, ive tried lowering min airflow, idle speed min, idle followers, airflow step down, raising area scalar, lower percent max to 0
only mod i done that i think caused it is the stock TB has been ported to take the lumps out, i have current tune file below and log
top pic is idle rolling with no TPS pedal but TB still opens dark green is pedal light green is TB
this pic is gear change TB drops lower but then increases for some reason holding rpm and affecting decel
