Just downloaded tuning software and match it up with my LS2 swap. I need help getting it to run with the new MAF. I went from the "round" to the "card" style and now it barely runs. I knew going in that this was going to be a problem and one of the reasons I bought the HP Tuner. There is a lot of information on how to go through the tuning process but most of what I read says that after I make changes, I need to drive the veh. How can I do this if I can't get it out of the driveway?! Is there a way to get right to the MAF calibration so that the veh is driveable? I can fine tune it later.
One other thing that I suspect is also causing some problems is the AIT readings. If I scan the cold engine, I'm getting a high AIT vs the coolant temp. Like 90 vs 70. This is before I ever start the engine. Once I do get it running, the LT and ST trims are off the wall but come back after 20 minutes or so. It's actually driveable at that point but once I shut it off, all the bad reading return. I understand that the PCM is adjusting the fuel trim and that it's going to go back to the original settings once it's shut off.
George
