I have a 2005 Mazda RX8 that I have swapped a 2008 L92 and 4L60e into. I have deleted the VVT with a BTR stage 3 cam. I am using an LS3 intake, injectors and MAF. I am using the E38 ECU with the T42 TCU to control everything and HPTuners to tune and log.
I?m having an odd issue with my setup and would appreciate help from anyone that may be able to offer advice to troubleshoot it. The problem that I am having is that under WOT conditions, the car will pull hard at WOT through first gear, then after the shift to 2nd the throttle will start to pulse and delay the pull through. If I apply the throttle gradually, it doesn?t happen. If I stay in it, it seems to eventually pull through it. I am not sure if it is a torque management issue or something else going on.
Thanks,
Joe
