Hey all,
I'm starting to tune my '13 Corvette again, after adding a DMX flex fuel sensor kit, and I'm not getting any KR data (not zeros, no counts, nothing). I've tried different sensor options from the drop downs, but none of the ones I've found work. The odd thing, is that older logs from 2-3 years ago (same car), are showing KR in the same table that isn't working now. I updated the HPT Suite yesterday, so it's on the latest version. Though the older logs are from an older version obviously. Was something switched in the newer revision that might cause this? Any ideas? Which parameter should I be logging? Am I just an idiot, and doing something wrong?
There are other parameters that aren't logging as well, though I haven't tried playing with them to try to get them working.
Thanks in advance
Troy
