Results 1 to 10 of 10
Thread: MAF Tuning without DYNO ? How good ?
    30
    Tuning a Denali 1500XL with 6.2 / 6L80 & MAST 216/230 LSA 116 - what are the expected results street tuning ? this thing is AWD and having hard time locating a AWD dyno . I have a long stretch of highway with slight constant grade - have the manual column shift feature where I can hold truck in gear . Any thoughts would be appreciated - thanks REM
    Mar 2010
    Texas Hill Country
    3,299
    you don't need a dyno, just a good wideband.
    Tuner hivoltagedriver's Avatar
    Apr 2013
    Oklahoma
    50
    I do all of my MAF tuning on the street. Just make sure you get enough drive time in to get a good data sample. I usually log for 10-15 minutes before making changes. I try to stay out of PE, and disable DFCO, CFCO, and LTFT's while logging.
    2017 JKU Rubicon: Purple, long arms, tons, 40s, Banks CAI, Borla cat-back, TD2/HPT tuned, daily.
    2017 GMC Sierra SLT: 6.2/ 8spd. Just getting started on it...
    Jun 2007
    1,100
    You dont need a wideband or a dyno. Just make a tune file setting pe to 1.0, disable transient, disable dfco. drop timing 5 degrees. flash the file and log in forced closed loop and forced fuel trim learn. log ltft hi and low, hit all freqs slowly. From the logged maf high and los trims, modify maf tables. reflash, repeat a few times to get as close to zero ltft and put the new curves in your finished regular driving tune.
    I am attaching a spreadsheet that makes it easy, just copy in the initial maf values from the tune, log trims, paste the logged trims in and copy the spreadsheet calculated maf values back into the tune.
    Aug 2009
    Calibrating
    3,373
    No need to set PE to command stoich... I see people mention that and is not true at all... out what you intend to target and match commanded vs actual!
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jun 2007
    1,100
    Ben, you are correct IF and only IF you have a wideband O2. Most cars I street tune do not have wideband sensors. That's why I use LTFT.
    Aug 2009
    Calibrating
    3,373
    I tune about 10 cars a week.... I put the car open loop and install my WB in the exhaust (takes me 10-15 min)
    14 Gen 5 Viper
    Jul 2017
    Can I have your mail pleas my mailis [email protected]
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by Nerabd1975 View Post
    [email protected]
    14 Gen 5 Viper
    30
    Sorry for the late reply - I really appreciate your responses here !
