g8 with a mild cam and lsa blower. I had the cam prior. id1050x injectors with data from dave steck. Although the injectors have been removed and reinstalled in a new rail? hopefully one of them is not failing or dirty?
as you can see in the logs, when I come to a stop the idle dips about 100 rpm below commanded, and the timing is like a saw tooth.
Ive gone back and fourth with the fuel trims, ive tried to really crank up the throttle follower and the case airflow and it helped slightly but really just wanted to push through the breaks.
Right now it seems best with the base airflow high but the follower just slightly lower then stock ?
I feel like its a timing issue but cant figure out why. over and under spark tables are stock, I did try to make them slightly less aggressive but it made no difference
what else would cause this? Ive tripled check for vacuum leaks, my only other thought is my brake booster line is 3/8 while the oem one is 1/2 but I don't think that should effect it like this ?
