I'm finishing up my Cummins swap into my 2007 2500hd classic, everything is working good so far , the only way I can make the ac come on is command it in hptuners, I'm using a duramax ac compressor and lines "it was a 6.0 gas" no codes from pressure switches, is there anyway I can wire it direct from the factory switches or bypass something to make it work, thanks
