I am having problems with tuning the idle on a 2002 escalade with a 2002 camaro version ls1 and a 2002 tahoe computer tune...confusing yes but we cannot get the idle to remain at the target idle speed which is set at 800rpm. it will run within the RPM error until the start up procedures are done then it drops down to 500rpm and stays around that figure and it doesnt matter whether your in PN or in gear, it is alil more drastic with the A/C on. Also durring braking at a stop sign the idle tends to drop right as or right after it stops, down to around 300rpm then jumps back to 500rpm still nowhere near the 800rpm target. thank you to anyone with the time to input
