Hello all. I'm new to tuning. I have a lq4 with 243 heads that have been milled .030. cam specs .610/.606 224/232 114 ls. tbss intake with 92mm t/b and long tube headers. This engine is on my airboat. My max engine rpm is 5800rpms due to gearbox ratio and max prop rpm. Right now I'm running 23 from 2200 rpms to 4000rpms. running 25 from 4000rpms and up. With this timming I can get the engine up to 5200rpms. I started with 21 from 2200 to 4000rpms and 23 from 4000 and up. with the 21 and 23 my max rpm was 5000rpms. I'm picking up around 100 rpms with each timing change. I don't want to hurt the engine by running to much timming. I'm watching my knock reduction and have none so far. The prop acts like a dyno. The more rpms I'm able to turn the prop at a set pitch the more power I'm making.
The tune that I'm working off of was done by a shop but I changed the intake/injectors/throttle body.
I'm running a SD tune. I've tuned the Ve table and have it running great but would like to make the most safe power I can. Thanks for any Help
