Hello
I have seen previous threads with this question, but don't understand still
How can I see the cam retard offset with the HPtuners Scanner or Suite?
I need to adjust it to be zero, on the distributor.
/Tomas
Hello
/Tomas
Which computer are you running. On my 0411 pcm it''s under offset in the channels. Was working fine for me just two weeks ago with the latest 3.4.89 software.
There should be a PID for it, you have to raise the engine RPM's above 1500 for it actually update and show the offset. Turn the distributor until it's zero or close to it.
