Have you adjusted your injector flow data for the bigger injectors? Also have you done any changes to the VE or MAF table?
The injector rate & VE table was updated when it was last tuned last year, it had been running ok. My plans was to get this fuel stuff straight then clean up the VE table a little. The regulator I'm running is off 2000 corvette system. Waiting for all the part to come in and will set up adjustable regulator with return line, to make sure the fuel pressure is steady.
