Results 1 to 6 of 6
Thread: P0606 amongst other codes made for a fun morning.
    Advanced Tuner Niemer's Avatar
    Jul 2012
    371
    Took off for work this morning and just about the time I turn onto the highway I get a backfire and DTC pop up. I turn around to head back home to get a different car and more backfires, poor throttle response and it eventually dies. A couple of key turns and it doesn't even fire the starter, a little while later I get it to crank, but no start, a little while after that I got it fired up and back into my garage.
    I pulled the codes when I got home, cleared them, and tried to fire it up to get a log and no starter again. Two more attempts with no starter before it fires up. Kinda baffled, it was running great up until now, no tune changes from running well to this happening. Throttle tables are stock, any ideas? Looks like I probably need to replace the cam position sensor (the starred code returned after I cleared them), I don't see anything obvious, it seemed to start and run fine, I haven't driven it yet, however.
    0x7E8: P0300 - Random Misfire Detected (Pending)
    *0x7E8: P0340 - Camshaft Position Sensor A Circuit (Bank 1 or single sensor) (Pending, Current)
    0x7E8: P0341 - Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or single sensor) (Pending)
    0x7E8: P0606 - ECM / PCM Processor (Pending, Current)
    0x7E8: P0856 - Traction Control Input Signal (Pending, Current, History)
    0x7E8: P2544 (Pending)
    Freeze Frame: 0
    DTC: P0606 - ECM / PCM Processor
    Fuel System Status: 01 01
    Calculated Engine Load: 26.2745098039216 %
    Engine Coolant Temp: 45 ?C
    Short Term Fuel Trim Bank 1: 0 %
    Long Term Fuel Trim Bank 1: 0 %
    Short Term Fuel Trim Bank 2: 0 %
    Long Term Fuel Trim Bank 2: 0 %
    Intake Manifold Absolute Pressure: 60 kPa
    Engine RPM: 2042 rpm
    Vehicle Speed: 61 km/h
    Timing Advance: 20 ?
    Intake Air Temp: 20 ?C
    Mass Airflow: 24 g/s
    Throttle Position: 18.8235294117647 %
    Run Time Since Engine Start: 1 s
    Commanded EVAP Purge: 0 %
    Fuel Level Input: 56.4705882352941 %
    Warmups Since MIL Clear: 4
    Distance Since MIL Clear: 119 km
    EVAP System Vapor Pressure: 8 kPa
    Barometric Pressure: 99 kPa
    Catalyst Temp B1S1: 10 ?C
    Catalyst Temp B2S1: 10 ?C
    Control Module Voltage: 11 V
    Absolute Load: 20 %
    Commanded EQ Ratio: 0
    Relative Throttle Position: 8.23529411764706 %
    Ambient Air Temp: 20 ?C
    Absolute Throttle Position B: 18.8235294117647 %
    Accelerator Position D: 19.2156862745098 %
    Accelerator Position E: 9.41176470588235 %
    Commanded Throttle Actuator: 12.9411764705882 %
    Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
    Jul 2012
    371
    Took it on a shakedown run last night without any issues, and the drive to work this morning went fine. Not sure why the ECM decided to go bonkers like that.
    Sep 2016
    39
    Control module voltage 11. You may want to check out the alternator. considering the system was at 2000 rpm that's lower than I personally would want to see.
    the other thing is the 1 second since engine start.... if the code popped on while you were driving and this freeze frame is from that event then something commanded the ECU to start (or restart) and that may have affected things.
    Jul 2012
    371
    Not sure what is up with that freeze frame, if you look at the log you can see the control module voltage is ~14.5 at idle. I don't really understand how these freeze frames work, but I was driving when the DTC popped up but just ignition on without the engine running when I pulled the info.
    Jun 2007
    Finland, Europe
    549
    Quote Originally Posted by Niemer View Post
    I don't really understand how these freeze frames work, but I was driving when the DTC popped up...
    It's a snapshot what was going on when the DTC popped out.
    Jul 2012
    371
    Well that is really odd then, wish I would have been logging when that happened. Hasn't happened again, yet...
