Seems like the ones having this issue are Camaro SS. Does the ZL1 use a different computer?
Sent the Debug and Info files from nx330mustang at comecst dot net.
Also attached a log and the tune if that helps.
Just had a O2 go out so the log is jacked.
My luck...
2010 Camaro SS 781rwhp
TKR Stage 4 CTSV 6L90
Circle D 258mm 3400 3B Pro Series Multi Disk
Kooks Ceramic LT's & full 3in exhaust
TFS GenX 255's (Polished PAC .660's and Ti-Retainers)
TSP VVT 3.2 cam
Smith Bro's trunnion kit
AEM X-Series OBDII Wideband Gauges
FIC ID1300x Injectors
ZL1 Fuel Pump
DSX Flex Fuel Kit / Auxiliary Fuel Pump Kit
MM Camaro 5 Wild
Holley Tall LS Valve Covers
NGK Iridium IX #7
HP Tuners MPVI2+
ProCharger D1X @ 13psi
Downloaded the 3.7x Beta and added FPDC under FSCM but it still only shows it stuck on 99.6.
What do you guys at HP Tuners need info wise to get this bug fixed?
I'll help all I can.
TSP VVT 3.2 cam
ZL1 Fuel Pump
MM Camaro 5 Wild
NGK Iridium IX #7
HP Tuners MPVI2+
