L92 swap LTFTs 23% prior to MAF tuning.. problem?
Hello all,
I have a L92 recently swapped into a landcruiser and am about to start the MAF calibration. Thing is, at low RPMs anyway, the LTFTs are around 23%. I understand for all tuning you disable LTFTs to reduce variables, thing is I'm worried about it running well 23% lean to get the driving cycles done for MAF calibration.
Should I do a quick adjustment of fuel tables based on LTFTs before disabling them for the MAF tuning? Will the STFTs take care of it?
I've been doing a lot of reading but don't see much about LTFTs this high. I have verified fuel pressure at 58psi.. no more fuel pump control module, I'm using a corvette filter with the built-in regulator.
Thanks for any help
