So yesterday i loaded a SD tune on my LS1 in the VCM editior and when i went to connect the VCM scanner i kept on getting this error. Ive never had this problem before. So I turned the car, hit the connect to vehicle button, it started to open all the drivers and loading the data then i get this error.
So then i close, shut off the car, close the log file. I then turn the key to start, hit vehicle connect, it works and its logging, then i start the motor and it logs for like 5 secs then nothing, data goes blank. I hit disconnect and reconnect then i get the error again. I loaded a different MAF tune and still the VCM scanner would not connect.
So im not having issues with the VCM editor. it connects and allows me to upload a tune. Just this VCM scanner is all of a sudden not working right. I tried disconnecting the battery for a bit. checked my OBD2 port for voltage and grounds, cables are good. Hell i just bought the HP tuners unit like a month ago. I uninstalled and reinstalled the VCM suite. Ive tried different config files. my laptop battery charger is NOT plugged in.
Could there be a problem with my PCM?? Or the scanner program? Could someone please help me out with this cause this is so frustrating that all of a sudden its not working.
