Since enabling boost enrichment I see trims shutting off at the kPa setpoint, but don't see the EQ changing. Motor just goes lean until PE is entered. Not sure what to see in the scanner but assume the PCM should use the richer of the boost table and the PE to determine EQ. I have both the Boost and PE EQs set the same for now. All is good once PE is entered....
No CL.hplSPARK+RPM_CL.hpt
PS: CL tuning is WIP
