I've read that there are 5 various parameters that need to be modified in order to properly control the injectors. I am trying to copy over the injector data from a LC9 flex fuel Avalanche tune over to my E67 LS2 CTS-V OS, since I'm using a T56 behind the LC9 5.3L and I'm using the LC9 flex fuel injectors. Everything is pretty cut and dry, but the tables for Offset vs. Press vs. IGNV are not the same between the two. The kPA columns are different. All the other tables are the same.
Offset vs. Volts vs. VAC (or Offset vs. Press vs. IGNV on the '07+ Gen4 vehicles)
Flow Rate vs. KPA (or Flow Rate vs. Press on the '07+ Gen4 vehicles)
Short Pulse Limit
Short Pulse Adder
Min Injector Pulse
This is what the LC9 5.3L table looks like:
This is what the CTS-V LS2 table looks like:
