Chris, I'm not seeing the new PIDs for my controller, E38: 12624402 -> 1250223
Ported TVS1900 OD cogs 10.5psi | ID850 | Vaporworx CTS-V 1:1 | COMP 219/233 .606"/.605" 113+1 | Ported TB | Pacesetter 1 3/4 LT | Solo Mach X3
It's the same one a page back 12635863 -> 1250230
What's been added to test?
~Greg Huggins~
Brilliant! Thanks Chris...... Works Perfectly! I've attached some logs so you can see it's working properly. No more issue. Been driving for the majority of the day, definitely is fixed. You can hold any gear WOT, it wont happen.
Just to clarify on this thread. It was a thing called "Injector Enrich Desoot Mode". Under Engine > Fueling > General. Set it to disabled to correct mid wot lean issue.
Chris added it to my tune, no doubt there'll be a few more changes to others........
2017 Toyota Kluger - 10.1" Android Custom Head Unit, Rockford Fosgate Speakers, 85kg Roof Racks. Prev: 2009 Cammed VE SS Sedan, DOD Delete, 210/218 550', RAMJet OTR, HiFlowCats, IQ System, Amp/Speakers.
Awesome, thanks for confirming it. Desoot mode modifies the injection timings to try and reduce soot formation in the cylinder. I'll go ahead and have the guys add this parameter to all calibrations. It is calibrated to have an enable delay of exactly 2 seconds after any enrichment mode begins.
Chris...
I count sheep in hex...
I can also confirm that disabling Desoot Mode fixed the issue. After 4 years, I can finally WOT in peace
Great to see a resolution to this.
Rob
2017 Chevrolet SS 6mt LSA
Prior - 2015 Chevrolet SS 6MT LSA
Old - 1998 BMW 540I Supercharged 402 LS2/T-56 swap
Older - 1992 BMW 325i 402 LS2/T-56 swap
Very old - 1995 BMW M3/ 402 LS2/T-56 swap
Can also confirm problem fixed Chris... Now just need to redial transients
Interesting that GM leaned them out to heat them up to burn off carbon then laid the fuel back to them... AND only in the e38's?
~Greg Huggins~
Chris....
How can I get this for 12614676 > 1250213
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
Would appreciate it on E38 OS 12653249->1250237
2012 C6 Base, Kooks 1-7/8" LT, Catted, NPP
Novi 1500SL, 10% OD IW, Big Blower Cam, Flip Drive, 2x Alky, ID1000
Nitto NT05R 305x19, 255x18 on CCW T10s
Self built and tuned https://www.youtube.com/watch?v=Kod2UTqrVwM
the work is in progress to add this switch to all E38 & E67 cals for now, we'll post here once it's done
Can you put a paragraph together on what the ECM did to create the spike @2.1 seconds. And what does desoot enable/disable actually do?
The current beta has the parameter added to all E38/E67 OS.
wheres the button located for the desoot?
I posted this screenshot in the other thread, but for those who haven't seen it - this is where it should be located...
~Greg Huggins~
At what point can "the rest of us" expect to see this in the production code?
2007 Z06 (E38 ECM), stock LS7 short block, .030" milled/ported heads, PLX SM-AFR, MPVI Pro
I expect within the next month. Meanwhile there is nothing wrong with requesting and using the beta.
Pretty sure this is desoot mode leaning it out but can someone please confirm?
definitely not. look at your map sensor reading, falls flat on it's face. looks like a massive air/vac leak to me.
