On the 2 logs I opened the worst lean condition is on different bank, however they are split by the same amount. There is a correlation here.
You are logging a lot of useless PIDs, try to make your datalog more useful deleting everything you don't need and focus on useful PIDs and increase polling frequency.
In both logs I can see a negative fluctuation in the air entering the engine, the MAF picked it on 1 log and the dynamic airflow on the other log. This suggests me that something mechanical or electrical is acting up.
Since PE remains active, injector pulsewidth isn't falling, fuel pressure doesn't drop and the ECM doesn't change commanded AFR I think it's possible that the lean spike is caused by a misfire or spark blowout.
The only obvious thing I can see in the log is that the voltage is very low, like you are running on battery only. In one log voltage is low until you go wot and the rpms rise it goes to 14.7X Volts, then it goes low again just before the lean spike. On the other log voltage is just fluctuating. It seems that you have an electrical problem. Voltage shouldn't fluctuate that much and anything below 13.5 V at wot is a problem.
I'd first check grounds, alternator and battery, then put new spark plugs with a smaller gap to rule out spark blowout.
