Is there any chance we can enable the no lift shift via HPT and just buy the TB, manifold, and cai separately vs. Buying the full power pack 3?
http://www.americanmuscle.com/frpp-p...-3-1517gt.html
I havent seen a no lit shift feature in the 15+ strategy, the no lift shift logic might be part of what ever strategy they change too when you flash their tune on. So I am thinking someone with the PK3 would have to try and pull the file for HPT to examine...Then we might have to do a strategy change to have it...
^^my theory anyway
Maybe that strategy is the one being used by Whipple / Roush. If so then the new update might make it possible to flash that tune if you could get someone to read one and send it to you.
Perhaps if the ECU was reflashed for the Performance Pack 3, and then the strategy was read via HPT, Eric might be able to unlock the tables (if it is as simple as that)?
Getting a read from a car with this tune would be a good first step.
Definitely would love to see a read out of the power packages, especially now that the GT350 manifold price just dropped like a rock ($520 or so), would be nice to spend about $700 on manifold + throttle body and flash the tune, pick up 50whp.
just go on fordparts.com, lookup a VIN from cars.com for a GT350, and then select a few dealers and you should see it
Is it GR3Z9424B? $1790 from Tasca Ford Parts
Change the B to a C and check again.
There was something like 5 or 6 in stock at various dealers last night, I just checked again and only see one in stock.
Here was my chat with Tasca a few minutes ago confirming the part number:
Chat session started at 16:52:29
Please be patient while you are being connected with an operator ...
You are now chatting with Matt
Matt:This shows to fit the gt350r 5.2 liter motor
Jordan:thanks!
Latest is on backorder and no one accepting orders until about June, F me. Sorry for the excitement, still fantastic news if the inventory does eventually come in.
Are you sure that is the intake manifold? GR3Z9424C is labeled as an intake manifold inlet.
Bump... I would like to see Ford's approach at tuning this combination if someone can get a read.
Hey guys, I'm the one that found out about the manifold pricing/part number change and posted it on Mustang6g.
YES the information is correct, the manifold has had some type of change that necessitated a new part number and the 'C' suffix is now the current revision. I have no info on what changed, my guess is supplier.
I had the same idea as the OP, not so much because I want the no lift deal, but because I want the PP3 components and the ability to use LT's AND have a factory like calibration. I am actively trying to trade a full SCT PRP tuning suite/X4/LaSota Base file/LaSota training kit with someone that has the PP3 Pro-Cal and wants to get more aggressive.
Has someone actually ordered the -C part number?
I did more research on the GT350 manifold and it looks like you'd lose torque almost throughout the powerband but gain horsepower at the higher RPMs, is this accurate? It seems like it would work better on the 5.2 V8 or with different cams, much like the FRPP 3V intake manifold with the 3V V8.
YES, but the quantities mentioned above are incorrect, there were never 5 or 6 in dealer inventory, the night that we found the supersession there were 3 in the entire country the next day there was 1.
I worked in a Ford parts department while I was in college for my B.S. My best friend eventually was promoted to manager and so I have access to Ford warehouse and dealer inventory numbers in real time.
I have mine on order.
Like anything else it depends on your set up. It was engineered for an engine with 15 more C.I.s and another 1K of usable RPM
