Results 1 to 16 of 16
Thread: 2007 gt500 large maf tube oscillating maf signal engine failsafe mode
    Sep 2016
    16
    Car has a large whipple, monoblade built motor etc.. I have it tuned well other than the occasional engine failsafe mode when taking off from a stop with light to medium throttle since changing from a 127mm maf tube to a 148mm for more range. I have tried everything I know of to cure this. The only thing I think I might have missed is a light maf voltage oscillation I have at low load with the 148mm maf tube that I didn't have with the 127mm. Any ideas? Also, is there a way to filter this oscillation out and how to do it? Thanks
    Sep 2016
    16
    No DTCs are shown after going into failsafe.
    Tuning Addict
    Jan 2015
    6,813
    Tune, log and then what your calling a large whipple is what per say? The MAF tube that came with the whipple kit should have been more than big enough... Unless you have a built 5.4l I'm not sure the engine will handle much more than 800ish to the tires and the 2.9l whipple will get close to that easily enough around 18psi on these...
    ~Greg Huggins~
    Sep 2016
    16
    whipple 4 liter,5.8l sleeved motor, ported heads, jdm SS cams etc. Currently at 22psi. E85. Whipple 123 maf tube and jlt 127 will peg the maf.
    Advanced Tuner 15PSI's Avatar
    Feb 2016
    East Coast Somewhere
    458
    Post your log and tune.
    2012 Mustang GT with S/C
    4Runner with S/C
    Turbo/NOS Hayabusa - 320RWHP
    Sep 2016
    16
    Will do. Going on dyno tonight.
    Tuning Addict
    Jan 2015
    6,813
    I personally just want to know what that thing puts down I can definitely see that pegging the MAF...
    ~Greg Huggins~
    Sep 2016
    16
    Solved the oscilation problem with foam diffuser in ram air from hood. Still have failsafe issue and is worse with smaller blower pulleys. Made 997 whp at 24psi through the 4l80e auto yesterday.
    Sep 2016
    16
    Its a 3.4 whipple not a 4.0. I mistated
    Sep 2016
    16
    Tune and log
    17-04-17 20-02-57.hpl17-04-17 20-07-49.hplNewMotor18.5DEGE85JLT148 24Dyno4.hpt
    Here are two log files that have car going into failsafe engine mode and the tune file.
    Dec 2015
    203
    So no dtc but you have a wrench light? What is your wheel torque error in that area?
    Sep 2016
    16
    I don't have a wrench light. Says Engine Failsafe Mode in the information display. Resets by turning car off then on. You can see the wheel torque error in the logs when I accelerate from a stop. Blips as much as -300 for a fraction of a second. I tried changing the indicated torque table by as much as 30 pct. doesn't seem to help.
    Dec 2015
    203
    Try making a graph and log your wheel torque error against the x and y axis of your torque table where the error is high make adjustments to the torque table then make sure you inverse it correctly on your inverse table....if you search there are a few threads on this. You will have to test and see how raising or lowering the torque affects the wheel torque error. I cant look at your file and log but ive also messed with the sd settings before and if there way off it will put it in failsafe with no light or wrench.
    Sep 2016
    16
    Problem solved!! Had to disable the SIP sensor tests
    Jan 2011
    VENEZUELA
    126
    nice numbers but that tune needs to be refined smooth spark table and work your maf it doesnt look smooth but any way nice numbers nice build
    i did one with a KB 4.2 it made 1250whp running on methanol at 21 lbs 11.0 c.r. custom cams bme alluminum rods and all the toys even trying to dial in a boost by gear setup on it with a waste gate
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    Quote Originally Posted by genesmob View Post
    what is the SIP sensor test? I current have the same "failsafe" issue on a 2005 Mustang 4.6 Magnacharger
