I'm trying to figure out the difference between the two speed sensor settings in HPTuners as I try to assist someone in getting a speedometer to work with an LS3-6L90E combo.
Under Hardware, it says:
>> Speed Output Type: VehRepTOS
Then, under Vehicle Speed Sensor, it says:
>> VSS Output: Disabled
First off, can anyone tell me the difference between "Speed Output" and "Vehicle Speed Output"?
I assume one is Transmission -> ECM communication and the other (second one) is ECM -> World and that this is what should be connected to the aftermarket speedo. But I don't want to just enable and wire it without understanding!
Thanks,
Dave
