Results 1 to 5 of 5
Thread: E38 2012 ZL1 Fuel pressure transition rate question
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Does the value shown below in the fuel pressure transition rate tables represent kpa change per second? Trying to speed up pressure change going into high flow. Higher value = faster rate of change?
    This table is from a stock ZL1 tune, mine is a ZL1 pump with ADM FPCM setup. Just trying to understand as it's been a while... Thanks in advance.
    Jul 2009
    2,305
    Well, no replies so hopefully this weekend I'll make some progress. Spent the last two nights getting v3.4 up and running to do logging with the scanner. Nothing like climbing that learning curve again at 60.
    Tuning Addict
    Jan 2015
    6,813
    Well Default is 100kpa which should be an aggressive setting, so not having messed with this myself - I'm going to "assume" that a higher number is a quicker rate of change as well
    ~Greg Huggins~
    Jul 2009
    2,305
    The screencap was from a stock ZL1 file and it shows 20 for the high flow transition, I can log commanded pressure vs actual so we'll see how it ramps. Looking for it to ramp up with boost, logging that and inj delta. Time will tell. Too bad the FP duty cycle shows 0 not running or 99.6% when running no matter what the commanded pressure in the scanner tho. Was hoping to log the DC as well.
    Jul 2009
    2,305
    Made a few test hits today, seems that the stock values are fine. As the pressure commanded steps up the actual pressure responds within ~0.1 sec. Ima leave it.
