Results 1 to 4 of 4
Thread: 2006 e67 on 2 bar? First time tuning boost
    Jun 2015
    NC
    201
    Hi guys,
    My current vehicle 2006 CTSV now has a centrifugal supercharger. This setup previously was on another 2006 ctsv, and as a result got the tune for the blower. For all intensive purposes im calling it a base tune. Setups were very similar.
    Can i do 6-7psi thru the MAF? Looks like this was done before. Are there any EASY ways to switch to 2 bar if i go SD route? Do i just slap in a upgraded sensor and change the axis in the VVE table? Does this change the O/S or patch it? Trying to avoid custom O/S or exotic solutions. Let me know if this base tune is on the right track and what needs to be done to goto 2 bar (2006 e67).
    Also attached a datalogged run when i was OL tuning the MAF. Wideband is done thru AC pressure sensor. Honestly haven't gone much past 50% throttle yet or higher than 4300RPM.
    Nov 2009
    All Around
    3,149
    you can get OEM LSA map sensor and tune away
    Jun 2015
    NC
    201
    So your saying all that's required is pop in that map and adjust the axis inside the VVE and im good to go? If i save the VVE table with new axis does this patch or modify the OS in any way?
    Jan 2014
    Australia
    1,983
    the VVE should already have a 3 bar option
