I did a quick search but couldn't find exactly what I was after. I just got hp tuners yesterday and am trying to go through a few things. One is my tire size and gear ratio settings to make sure it is not affecting my transmission shift quality. So under the speedometer window I have the "calibration" tab open. So these are the numbers I need to make sure I have figured out:
VSS Pulses per rev - trans.
Trans revolutions/mile
Final drive (3.70)
VSS pulses per distance
Pcm output calibration pulses per mile
Speedo abs ppm.
So any help is appreciated, for what it's worth it's an 05 gm truck ecu, 3.70 final drive, 4l60e, and a 27.3" tire diameter. Thanks!
