Ok guys looking for a lot of help here, I installed a BTR stage IV cam, a BoWhite TB, a Vararam (tune req) CAI, and a 160 stat, gears will be going in at a later date. Ok exit intro
The car fired right off and anything below 3K rpm it ran, idle was too low and sluggish MAF/Stabilitrac kept going in and out until Rs were up, but stayed running it went into limp mode as soon as it went over 3500 with moderate acceleration. I had a custom tune installed already, originally from a Diablo but now on HP, for LT headers and cat-delete full 3" exhaust. I am no tuner at all but I managed to search the repository to find some I could cut and paste from to get CEL to clear and help the idle and I am not going to be on a dyno anytime soon. Once break in is done, provided I manage a good tune then it may see the bottle at which time it will spend time on a dyno, if I go that far. My tuner I work with isn't sure if he will be able to get me a good tune since I have a cam and bolt-ons, not until I can get him some logs after 150+ miles of running. He recommended I reach out to the HP community for additional support, attached is my bastardized(current tune) tune to get codes to clear and idle and the other is the tune I had before the cam install(stockDiablew pre cam tune). Just looking for help to get the best out of this setup.
Much appreciated guys
