Results 1 to 8 of 8
Thread: 2010 L99 Camaro can I disable the traction control in the tune?
    I know if I hold down the traction control button for 7 sec it will turn off the system. My question is can it be done via the tune so I don't have to press the button every time I get into the car?
    If so how??
    13,565
    Nope.
    Unplug the an ABS sensor or wire in a signal cut switch to a wheel bearing (redneck method). The most you can do is really reduce what ways the computer controls traction with fuel cut and spark etc etc.
    Traction control and stabilitrak can't touched with HPT.
    Jul 2012
    Florida
    1,460
    When I go to the drags, I pull the traction control fuse. It beeps and flashes stuff on the dash, but it is so noisy there, I can't hear it anyway. It is REAL aggravating driving around town though.
    2013 Silverado 5.3, 6L80k 8.8
    Tuning Addict
    6,816
    You can kill it in the tune in a 2010 Camaro... Torque management - General - TCS Method - disable all / You can also dial in max torque settings if you want traction, but not as much of it and you can kill versions of traction such as wheel hop... You want it completely killed beyond doubt - TCS Method - Disable All, Raise max tq to 8100 in TCS method section and Disable all Powerhop settings...
    ~Greg Huggins~
    Tuning Addict
    6,816
    You can actually kill it in pretty much all gen 4's...
    ~Greg Huggins~
    I will give it a shot! thanks for the input
    Jun 2007
    1,100
    All you have to do is set the TCS enable temp to any temp above normal operating temps, like say 492?
    Jan 2006
    DFW
    249
    This. I have done it in my 07 Tahoe E38 as well...
    2008 Denali XL AWD LSA Blower
    2010 CTS-V
    2005 LLY Duramax SAS
    2015 Denali
