Results 1 to 3 of 3
Thread: 0x7E9: U0100 - Lost Communication With ECM/PCM A (Permanent)
    Dec 2016
    7
    why do i only see this in hp tuners no check engine light. Is this an issue with software?
    car seen to run fine.
    Dec 2016
    7
    re flashed with stock tune code went away. its just weird that the check engine light did not come on..
    HPT Employee Mark@HPTuners's Avatar
    Jun 2014
    36.1094, 115.1781
    432
    The U0100 code is common after a re-flash. The reason it did not trip the light is because the code is Permanent and not Current/Pending. More information on Permanent DTCs can be found here:
    http://www.hptuners.com/forum/showth...nd-VCM-Scanner
