Results 1 to 20 of 22
Thread: What would cause a P0016 after cam install?
    Tuner in Training machineworks's Avatar
    May 2009
    Pasadena Texas
    42
    I am tuning a C7 for another shop. This code is coming on. The think they timed it wrong.
    Probably a tooth off. Chain may have jumped when they released the tensioner. It's definitely worth the time to spin around for a double check.
    Could have a tooth off. Try a crank relearn if you know it revs freely. Do you know if it's a VVT cam? Possibly they installed a phaser limiter? Or installed the phaser limiter incorrect.
    I would not do a case relearn until it is checked. Rev till fuel cut is asking to for trouble if the timing is off.
    Quote Originally Posted by rbooth View Post
    Obviously. I only mentioned that if it has gone that far successfully, prior to now. In which case the damage is already done or no risk when revving. However, if it has not already been revved that far, then I would definitely check the sprocket alignment.
    If I recall someone had that same issue not too long ago and they reported a crank relearn was the repair. I know of the cams I've installed, I've never seen that code come up post install.
    Unfortunately, I have seen a friend make this mistake. The valves will not hit at idle or low speed but the can tap the pistons on a high rev decel when the tensioner give a little. Not questioning anyone but I have seen this exact scenario play out. I as well have never seen this issue with a properly timed cam swap
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Besides the DTC does the engine run OK? Idle? does it make a power curve that looks sane?
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Honestly, I've had a couple doing cam swaps that set this code. 3 to be exact, and each time I had the tech tear it apart, to verify timing, and nothing. would restart and code still there, but would eventually just disappear through the tuning process. Its a little un-nerving to see it. Not saying to ignore it, but I have seen it as a phantom code
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Dec 2006
    Rockwall, Tx
    247
    We were having this same code randomly appear until we started locking the VVT gear out completely.
    Dec 2013
    Slidell, La.
    1,015
    You might be on to something, as all of mine were not locked. it does make sense, for it to be there then eventually learn its new fluid pressure values. hmmmmm
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Dec 2016
    19
    I did a cam swap and deleted the cam phaser and just went with a reg sprocket. I did the swap because for years I was getting a P011 code. Been to dealership numerous times never fixed. I now get that same p0016 code. What is this relearning process that is mentioned here?
    Dec 2016
    19
    Locking VVT out completely? What exactly do you mean? Is this something you are doing with tuner?
    Aug 2009
    Calibrating
    3,373
    Just disable the VVT in the tune and mod the VVT table (0 out)
    Dec 2016
    19
    Ah ok thanks
    Aug 2009
    Calibrating
    3,373
    There is multiple tables but it's easy
    Dec 2006
    Rockwall, Tx
    247
    I wasnt talking about zeroing out the VVT tables. I was talking about locking it out with the phaser in the motor by blocking it completely as opposed to restricting it with the Comp cams block.
    Dec 2016
    19
    Oh I don't have that option anymore, factory cam and phaser are gone. Got a cam from comp cams and installed regular sprocket
    Jun 2007
    38
    OP did you ever figure out what was going on? I am dealing with a similar issue on a 2016 camaro. p0011 and p0016. He installed the cam with a comp cams phaser limiter as well.
    Dec 2016
    19
    Not a 100% sure what the isue was, I believe when the DOD kicked in 1 or 2 of the valves were either closing or opening in correctly. I got a 3 wire pig tail to connect to new timing cover and cam sensor. But that gave me a p0010 cam circuit issue. I just set the mil error not to report that. P0016 haven't solved that yet.
    Dec 2006
    Rockwall, Tx
    247
    What year car are you referencing? 2012?
