Results 1 to 10 of 10
Thread: Throttle Issue
    Throttle Issue
    The truck pedal does not work sometimes when taking off in first gear. When you try to take off, the pedal does not work, you can press it to the floor and the truck will not move, no rev, no changes in fuel trims, no DTC codes are thrown either. It acts like it lost communication with the tb. Stock gm dbw tb.
    Swapped the pedal and tb and it did it worst.
    Any thoughts?
    Any codes??
    Be sure that the codes for the ETC are not set to CEL off,Do not report,etc.
    Check pin terminals on the APP,TAC,TB for loose terminals.
    Also the TB connector wires break in the harness.
    Check the TPS readings with a scanner to verify that the desired and actual TPS % should match or be very close.
    The voltages should also match or be very close.
    Quote Originally Posted by Earwax View Post
    Any codes??
    No DTC codes
    Tuner CousinChevro's Avatar
    Apr 2016
    Whitehorse
    61
    I've been having a royal pia with this exact symtom. Its p0606. Clear it, get pedal back, rev it up.. it dead pedals.. . It wasn't throwing the DTC untill the 10th time i read and cleared dtc's in scanner. Maybe not the same problem you have.. but i found a tune close to my set up in the repository. Totaly runs like shit now but the pedal works flawlessly and no more p0606. Maybe try setting No reported for that DTC
    If you can't fix it with a Hammer, You have Electrical problems.
    Tuning Addict
    Jan 2015
    6,804
    This usually happens when you mess with the electronic throttle / desired throttle / driver demand maps... Even if all you do is change the axis a little - it can really tick it off...
    Even if you set the dtc to not set it will still kill the engine... It's a safety of all safeties...
    ~Greg Huggins~
    I left the (electronic throttle / desired throttle / driver demand maps...) all stock.
    The crazy thing is it does not do it all the time. It went 7 days without doing it, then it started doing it again. And it occurs at very light throttle. I mean barely moving. Very slow throttle. For example, started the truck, moved from the parking space in the parking lot and then loss the pedal while in the parking lot moving at less than 5mph.
    Now if you go WOT or get aggressive with the throttle, it does not occur, only at low speeds.
    I noticed under torque management, the etc limit was left enabled. If the etc limit was left enabled could this cause the loss of pedal?
    Mar 2010
    Texas Hill Country
    3,299
    I don't think you have a tune issue STR8BALLN.
    Apr 2016
    Whitehorse
    61
    Thankyou!
    Sounds like a wiring issue. In swaps I have seen this happen is a ground is loose.
    Mar 2010
    Texas Hill Country
    3,299
    The ETC Torque Management table counts as a throttle table even though it is not in the Electronic Throttle tab. I could make this all 100 on a GenIII but on a GenIV it kills the relationship between the pedal and throttle.
