Hi guys so I've searched and searched and havent found anything. Basically what I'm trying to do is wire in another MAP sensor to my dash logic so I can monitor crank case vacuum output by my vacuum pump. To do this I plan on using a ls3/ls7 map sensor I had laying around.
Here is the question, I need to make a pid to convert the 12591290 map sensor voltage into a KPA reading I can work with. Does anyone know what that pid is from GM?
I found a 1 bar conversion for GEN III sensors which is (V/.0533+10.35) but as far as I can tall it doesnt work with the ls3 style sensor. Can someone help me out here? I suppose I could go get an ls1 style sensor and make it work but I'd rather try to make this happen.
