Well I actually have two controllers both with the same custom os I designed, one licensed to efi, one licensed to hpt, I own both efi, and hpt. I useually just create custom os, or remove vats or setup injectors ect for poeple to beable to driveva block to a tuner.
But since this rides my own and I have the software I thought I'd give it a try, tune it myself.
I've only tubed ounce in my life few years ago, with a e40 and hpt, wideband afx ntk through ac port.
Now I love efi, because I can make custom files. But never tuned with it, before and there doesn't seem to be a way to run a wide band through efi at the ac port. At this point it may be faster to rewire my wide band to my efi interface directly has inputs. And learn that software tunning curve.
Hpt I'm more used to using, then efi but that's 2.24 hpt, v3 is a new ball game!
I only have one minor complaint about efi it writes slower then hpt, at least it seems that way? But I think I'm done with hpt for the time being, might as well use efi?
Sounds like you have both? Which do you think I should use? I'm open to using a combination of both as well
