Results 1 to 3 of 3
Thread: Powerdyne supercharger
    Aug 2010
    On the third rock from the sun
    94
    I have a Camaro 3.8 97
    Question is I got a power dyne supercharger with a 9 pulley on it now. Don't have header on yet. But does anyone know the max PSI I can get away with without header? I can change the pulley to lower the PSI on the supercharger if I need to. Oh one more thing, I don't have any cats on the exhaust it is straight pipe flow master no headers and K&N intake.
    13,565
    I'd say under 10psi.
    You will likely be limited by fuel injector size and only be able to run low timing, somewhere in the 12-14 range.
    Aug 2010
    94
    I can work with that. Thank you for the reply.
    I already know about spark plug type and gaps. and lower the PSI I have no problems with. Kool time to have a little fun.
