Results 1 to 9 of 9
Thread: 6.0 with a supercharger wont run on correct injector data but will run on stock data
    Nov 2012
    37
    Im having a issue and hopefully someone can point me in the right direction
    I have a 6.0 lq9 with a tvs1900 runing 42 lb injectors from magnuson.
    I have the magnuson supplied injector data and it has worked before on other installs .
    On this engine if i enter the Magnuson supplied IFR and offset data the vehicle will fire,Sputter and die.I can attempt to keep it alive using the throttle but its a near no go.
    If i keep the factory IFR and offset data the truck runs ,Idles and can be driven but my stft is of course pegging positive,and as soon as it enters any kind of boost wants to go Totally lean and cough/Sputter die.
    i can drive it down the road on the factory numbers at most normal speed but again cant get into boost.
    I cant drive it or even idle it on the correct IFR and offset for the 42lb inectors
    IF i keep the NA IFR but not change the OFFSET it wont run either,Both have to be changed
    But if i keep the VE tables the same across the board theres no affect.
    I have attached the log files for both
    Is there something im missing ?Where can i look to find a solution ?Are the injectors trashed?Is the data wrong?
    I dont believe i have a vacuum leak and i have partially ruled out mechanical issues since it will idle on the NA data but not even fire on the corrected IFR
    Any help will be appreciated Kinda at a dead end here
    Nov 2012
    37
    Anyone have any idea ?????
    Could use some help here
    13,568
    Your files are tuner locked, can't really help you.
    Nov 2012
    37
    just re uploaded the tune files Unlocked .I thought they werent locked sorry for the mixup
    Tuner in Training kainedogg's Avatar
    Feb 2013
    14
    In for the input.
    Nov 2012
    37
    anyone?tunes are now unlocked
    Feb 2006
    central michigan
    349
    your injector data off by a bunch.need to add 14-15 lbs/hr.are you using a two bar map ?
    Nov 2012
    37
    Quote Originally Posted by miker2 View Post
    using stock MAP sensor
    Should i at 15% to the IFR and leave the offset table alone ?
    13,568
    Shoulda gone with a 2 BAR OS, you can't even tune the VE for boost with a 1 bar MAP sensor nor can you log boost with it either.
    No idea on injectors, never used them.
