I would like some advice on steady state tuning. I have yet to write up the base tune for it but I will be setting the car into open loop via the HPTuners e40 pcm write up. I will be tuning for both Speed Density and MAF as my GTO does not see more than 2Bar a grand total of13psi. On the street tuning the car with the MAF I have not had any issues. I just want to compare MAF to VE.
For SD,
I am familiar with the concept of steady state tuning when it comes to NA VE. My concern for 2BAR type tables is how to tune the heavier load ranges of the table(s); particularly when it transitions from Vacuum to Boost. IOW's do I continue holding load in each cell transitioning into the lower boost VE table, say for example 1-3psi, aiming for 14.7:1? Or do I save the Part Throttle style tuning for the Vacuum side only stopping at 100kpa.
In addition,
This GTO runs a dual pump set up with a vacuum regulated return line. The secondary pump is activated via a HOBBs pressure switch at roughly 6psi. I have already adjusted base fuel pressure via the regulator at the factory recommended 59psi. What should I expect to see when the car goes WOT on the dyno with this set up. Will I be able to smooth any effects the secondary pump activation will have on the AFR with just tuning the tables or is are their other parameters that should be addressed as well.
