I have a 0411 PCM that i cannot read/write due to an invalid checksum error. Is it trash? Or can i do anything with it? I believe the error is due to being tuned with another software, may or may not include a custom OS.
This just happened to me too. Only got 2% into the read and "Invalid checksum" pops up. Probably has a tune locked on it, haven't found a solid answer yet though?
check module voltage /add it in your channels make sure its not below 12v
Remote Tuning [email protected]
Ive found that if you have the original tune file or a file you previously worked with for that ECM, you can flash that onto it and you should be able to read it again.
If you did a write entire with a different tune, but the same OS, would that work? I'm only curious because my dad's lml duramax did this, and hp tuners support said it needed to be reflashed by a dealer, didn't consider doing a write entire with another tune. Though, would that make you burn 4 credits?
2000 K2500 - 489 CI Vortec w/ comp XE270 cam - 0411 swap and rear mount turbo
1972 M35a2
2011 LML Duramax
