well good you removed that one, because i removed the other one and it locked up again at 32m 15s. I'll run 3 again just to be sure, then I'll remove the other knock retard you had.
It runs noticably slower on this tablet (graph updates slow down when RPM and things change fast.. faster the change the slower the updates but doesnt seem like that is affecting the data freeze yet.
My specs on this tablet are worse than yours, I have 2GB RAM you have 4GB, I have 1.33ghz 4 core you have 2ghz 2 core? I'm getting 30mins out of it. Not sure if the computer specs even has anything to do with it yet but if something is eating up memory then yes it might.
After all this I'll add all my graphs to all your graphs and see what happens.
UPDATED POST #98 with freeze updates
