Results 1 to 7 of 7
Thread: New cam, got a issue....
    May 2006
    7
    Well I installed a new cam this weekend and now I can't get my 2006 TBSS to start without giving it some pedal. Once it starts it idles fine and doesn't stall. What do I need to do to fix it?? Any help is appreciated.
    Cam = 232/242 .600"/.600" on a 112lsa
    The truck also has a Yank SS3600 and exhaust. No header or CAI, yet.
    Thank you for the help!
    Moderator WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    7,864
    Did you tune the VE/MAF yet? What is the idle set to? Did you do the idle airflow yet?
    Sulski Performance Tuning
    2000 WS6 M6
    Old Setup: 480 rwhp 437 rwtq with 230/232 cam and a best of 7.17@98.47 w/1.58 60'
    New Setup: AFR heads, 11.6:1 CR, 90 mm ported FAST, Exo-Skel, 236/244 custom ground cam, QTP HVMC, EWP, GMMG, 9" w/4.11s
    May 2005
    Conway, AR
    346
    might have some cranking VE issues. Also though, idle airflow needs to be bumped up like said above. Whats the idle rpm you have set?
    2009 Silverado Crew Cab 5.3L, stock.
    May 2006
    7
    Guys, thanks for the help. I have the idle set for 1050rpm. I have bumped up the start up airflow. I have not touched the VE / MAF yet.
    Once the truck starts with pedal it seems to run pretty darn good, drives fine and idles good. No surging or bucking really. Keep the help coming, I am new at this and can use all of the help I can get.
    Jan 2005
    Concord, NC
    7,864
    do the VE and MAF tables, there is really no need to post about questions or issues until you have them dialed in, that will give you so many problems and is the first step in tuning.
    2000 WS6 M6
    May 2006
    7
    Quote Originally Posted by ws6firebirdta00
    Ok, where do I find how to dial the VE & MAF tables in at? How do I do it?
    Jan 2005
    Concord, NC
    7,864
    read the stickies, that should get you started
    2000 WS6 M6
