Results 1 to 20 of 21
Thread: Chris a little help?
    28,273
    This is a SD/open loop question for the I5 guys
    1. When in SD mode should it drop into Min VE table only?
    2. To set up open loop fueling to stoich should we just set the 5 tables to 1.0?
    3. The OLFA Gas(gear) & Gas(P/N) tables what does the vertical access represent? Its in Fehrenheit but im not sure what it is exactly? tranny temp? iat? ect? something else?
    4. Should we set the o2 readiness temps high or will the ect startup temp overrule that?
    im sure theres more everyone would like to know but these are some of the questions on my mind.
    May 2006
    Tucson, AZ
    62
    thanks for posting these questions foff... i was just looking at the tables with my mouth on the floor wondering why these tables have to be so much more complex than a v-8
    2005 Chevy Colorado
    4/4 drop
    1.25" thick front and 1" thick rear sway bars
    Nitrous Express wet kit
    billet servo
    JL12W7 in custom ported box w/ Phoenix Gold 1200.1
    28,273
    they arent...take a look at an ls2/ls7 file
    May 2006
    Tucson, AZ
    62
    i haven;t looked at a LS2 or LS7 file but i do remember reading that they are very hard to tune compared to other motors, thanks for putting things into perspective for me .... plus i am a newbie to tuning so all this stuff makes my head hurt from time to time learning what affects what table and knowing that one wrong change could blow my 8,000 motor up
    2005 Chevy Colorado
    4/4 drop
    billet servo
    28,273
    the last couple of years have brough huge changes in the way we tune & what & how.
    May 2006
    Tucson, AZ
    62
    well hopefully Chris or someone will see this and get on here and help us out or hopefully at least somebody will know cause i don;t really want to go into SD mode and not know what A/F i am commanding
    2005 Chevy Colorado
    4/4 drop
    billet servo
    28,273
    just log commanded afr in the scanner you'll be able to see...I don't have readily available access to a colorado/canyon though so the only testing I get is when im tuning them.
    May 2006
    Tucson, AZ
    62
    i don;t have a wideband and 2.1.10 and the new beta 2.1.11 don;t even support our factory narrowband O2 sensor, so i am not sure how i would log the commanded a/f, if i am just going to have to get a wideband now then i guess i will charge one... i just don't have the cash right now
    2005 Chevy Colorado
    4/4 drop
    billet servo
    28,273
    I logged it the last tune i did remember its only the "commanded" a/f ratio not actual.
    May 2006
    Tucson, AZ
    62
    oh well if that is all then could you send me the histo you have set-up for that so i don;t have to spend the time to set it up???
    2005 Chevy Colorado
    4/4 drop
    billet servo
    28,273
    Quote Originally Posted by jaronow
    this should work I made it up the other night
    May 2006
    Tucson, AZ
    62
    sweet, thanks a bunch bro... when i leave home from work i am going to put this bad boy into SD mode and see what it does, i'll let you guys know how it goes late tonight or tomrrow morning.
    really quick, i need to reset the fuel trims once i upload the tune and start the truck up for the first time in SD right and then after that i don;t have to do it again, right??
    2005 Chevy Colorado
    4/4 drop
    billet servo
    28,273
    i dont really tune by trims so im not sure...i usually just turn them off & tune with my wideband.
    May 2006
    Tucson, AZ
    62
    ahhh... got ya
    thanks for all the info and help over the last week... i really understand the softare much better
    2005 Chevy Colorado
    4/4 drop
    billet servo
    Quote Originally Posted by foff667
    1. afaik it will still use all the VE tables, they are selected based on the cam position and if the Multi VE option is enabled.
    2. they all multiply together for the final EQ ratio. 1.0 in all tables would give you that, but on some LS2's GM calibrates one table at 10.0 and another at 0.1. Regardless, as long as the final number is 1.0 it will do what you want.
    3. Intake Valve Temp
    4. both the enable temp and the o2 readiness need to be set high to disable closed loop completely. If you leave the o2 readiness then the STFT's will still operate.
    Chris...
    I count sheep in hex...
    28,273
    Thanks Chris, we needed that
    May 2006
    Tucson, AZ
    62
    thanks a bunch... i am making a few more tweaks to enter SD and i will be out of here to try it all out
    i'll post up the results later
    2005 Chevy Colorado
    4/4 drop
    billet servo
    no probs, apart from the multi VE stuff they are basically identical to the LS2's
    Chris...
    28,273
    oh, is that all? lol
    May 2006
    Tucson, AZ
    62
    well.... the truck liked being in SD mode so far... i had it almost die while idleing twice yesterday and other than that i have had no problems. However my Air/Fuel error is at -13 all over the board.... so now that i have my data i am going to being attempting to get these VE tables right
    2005 Chevy Colorado
    4/4 drop
    billet servo
