ok, need input. swapped a 5.3 into a 78 k5 blazer used the th350 trans, tbody is iac , pcm is a junkyard one supposedly from 01 Tahoe part #12200411, engine is 2003 Yukon, injectios and rail are from 07 sierra denali lq9, new cmp and ckp sensors, harness from modern vintage, disabled vats. problem I have is it wont start, I have tested and have 55-60psi fuel pressure, spark and injector pulse. however while spinning it will "hit" occasionally but never start up, but if I spray carb cleaner in the t-body it will run, if I keep it running with the spray for 3-5 seconds it will continue to run under its own power like normal. if I shut it off then try to restart it immediately it will. but if it sits for 5-10min wont restart. any ideas? thanks
