Getting ready to tune the car. There are no apparent leaks in the system but everytime I turn accessory power on only, fuel pressure drops to almost nothing like 5 psi as if there was a leak. Although when I do start the car fuel pressure jumps right back up and it holds steady at 59psi. light revs and it holds steady. should I be concerned and can this be tuned out?
its a lonnies dual walbro 255 system with a fuel labs regulator on the return line the regulator does have a vacuum port but I have not yet connected it.
