Since we converted from 2.24 to 3.0+, we lost our list function which had previously enabled us to use Non-linear Wide bands. A few have asked about it, yet there seems to be no response or movement to resolve this issue. I had an idea, but wanted to throw it out there, before i go wasting a ton of time on something that might not even be possible logically. Was wondering if i could incorporate a list into a math function as a long row of IF statements that would convert the voltage from the wide band to its associated paired AFR value. For example: a voltage is read, the function would go through all the IF statements till it matched the value, it would then spit out the AFR value attached to that particular IF formula for that voltage.
So i'm asking any Scanner pro's out there, is this possible, even though there will be tons of IF statements that will go into it.
