Results 1 to 3 of 3
Thread: commanded throttle vs. actual throttle
    Oct 2009
    27
    At full pedal, 100% commanded throttle, the most throttle i see in the scanner is 39.1%. What's up with that? I don't have anyone to push the pedal while I look at the t.b.
    Tuning Addict
    Jan 2015
    6,815
    Make sure your logging the right tps reading - log multiples if need be until you find the one that displays correctly... Unless your way low on power - I would bet it's opening up correctly...
    ~Greg Huggins~
    Oct 2009
    27
    Ok. Thanks. Ill check that tomorrow. I know there are like 12 diff "throttle" pids.
