Is it possible to connect my Serial WB connection data lines to the inputs on the HPT box so I can use the serial connection while stand alone logging without the laptop?
If not, could this be something useful?
What would be required to do so, such as Serial inputs instead of analog? I was thinking this could be converted in the software.
This way you have the luxury of not having the voltage offset when using the analog signal wire?
