Results 1 to 10 of 10
Thread: Can I added wheel speed sensor reading to my log?
    Tuner in Training b2319dragracer's Avatar
    Jul 2013
    Dundalk, Maryland
    25
    I would like to use ABS wheel speed sensors as a way to see tire tire slip on launch.
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    283
    . Guess it depends if that info is provided by your ECM. I have a scanner setup plotting the difference between front wheel speed and rear wheel speed to track what's going on at launch. Yet to try it, but should work
    2012 C6 Base, Kooks 1-7/8" LT, Catted, NPP
    Novi 1500SL, 10% OD IW, Big Blower Cam, Flip Drive, 2x Alky, ID1000
    Nitto NT05R 305x19, 255x18 on CCW T10s
    Self built and tuned https://www.youtube.com/watch?v=Kod2UTqrVwM
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Should be a driven wheel speed and undriven wheel speed you can use for this.. in theory anyways. Depends on the vehicle but look for that
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Jan 2014
    Australia
    1,986
    i was using the driven and undriven speeds the other day and it is good to watch wheel spin, since my front to rear are staggered wheels/tyres there is a 0.5-1km constant difference in the reading, then anymore then that is spin, it actually amazed me how much the rears do spin compared to fronts
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Could probably do a math parameter subtracting the two and factoring in any difference you normally see then graph or chart that, if you aren't already
    Jul 2016
    Flanders nj
    283
    Using ([8006.56] * 1.1) - [8005.56] where my rear tires are 10% taller than the fronts.
    It's interesting to see how the RPM difference between front/rear go from +10 RPM difference on hard accells to -10 PRM difference on heavy decells. Has to be a change in diameter as the car squats then then front pushes down.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    That's pretty neat, I'll have to play around with it some time
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    hopeing the Outputs get working soon cause I wanted this to trigger a light when I'm spinning past a certain point. Fun Factor.
    2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
    Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
    LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
    ZL1 Wheels/Tires
    Jul 2016
    Flanders nj
    283
    Quote Originally Posted by 10_SS View Post
    You and me both. I want to use that output to take some spark out.
    Would be super cool to get a frequency output proportional to the result of a Math function.
    Jul 2013
    Dundalk, Maryland
    25
    Thanks for all the feedback. :-) Very appreciated.
