Results 1 to 3 of 3
Thread: Speed Density tune to pass ca OBD scan
    Feb 2015
    11
    Hey guys, currenty have my sierra tuned to run in speed density, which still has 2 dtc's that set, but the MIL is turned off. I need to smog the truck for a sale, and in CA I cant have any DTC's detected by the scanner. I was hoping someone can help me figure out what to change in HPT's need to be made so I can at least have it pass the OBD test, then I can just revert back to the SD tune.
    I guess just turning off the codes will cause the truck to not run or run very poorly. I just need it run enough to have all the readiness codes complete and not DTC's
    13,559
    The truck "should" at least run fine for a little bit if you set the MAF dtc's to no error reported. Then you could revert back to first error with the SES box unchecked.
    Feb 2015
    11
    Tried it last night but it wouldn't run at all, would fire up but die. But it also was a cold start, wondering if once it warmed up and in CL it would run
