Results 1 to 9 of 9
Thread: Please Help , take a look 01 camaro 408 tfs245s 244 248 cam fast 102 102
    please look at my tune i need help!help
    bump ,bump,bump
    13,565
    And the question is what?
    Most posts have a question in mind. You need to add more stuff to the scanner too, like the other LTFT, injectors, knock retard.
    MAF and VE need more work based off the trims I saw in that log. The VE just looks like you added 5-10% to the whole table without really tuning the table in speed density by itself.
    Oct 2012
    gadsden al
    170
    the idle has not been tuned but we need to know what you need help with
    it runs crappy idle sucks,where should i start at with tuning
    13,565
    Quote Originally Posted by Camarovon View Post
    Then the answer is everything I guess.
    Make sure all data is correct for the parts you are using like MAF/MAP, fuel injectors and such. Read up on idle tuning and then start tuning the VE and MAF tables so it can have correct airflow data.
    bummmpppp
    Banned
    Oct 2016
    379
    bummmpppp
    What are you "bummmpppp"ing at? You got an answer. How about a "thanks"?
    Weird things I noticed:
    - the MAP is reading twice as high on idle as it is to my engine
    - the MAP decreases instead of increases when the revs climb
    - the Spark Advance table only reads cells/data in the first horizontal line (0.08 Cylinder Airmass on my graph)
    - Power Enrichment Delay starts at 0 rpm
    thanks guys
