2 Bar SD, tune attached is what I am using for tuning - so DFCO and closed loop are disabled
I read up on EOIT and how to do it, and used the spreadsheets to get to my numbers. The only problem is, when I increase the values in the Normal EOIT table, the gas smell gets worse - even when I correct the AFR to a lean ratio at idle
I have attached images of my cam card, the EOIT spreadsheet values, a spreadsheet showing how I got the numbers.. I tested the car at 6.22 and at 5.96 (current value) and neither of these values helps with the raw fuel smell
It is so bad that it burns your eyes.
2005 LQ4 w/ 69mm turbo, BOSH 650 CC injectors (I used the provided injector data by Fuel Injector Connection). Cam specs are on the card image below
Anything I am doing wrong?
Chevelle2Bar.hpt
