I have asked on ls1 tech, chevelle's.com, William's performance, and Dr. X Link and I can not get an answer from any of them other than I don't know. I have a 2005 8.1 with a P59 Blue Green pcm that I cut up the intake and installed a 102MM throttle plate. I have the complete TAC system and harness, but no one can tell me if I can rewire the harness from the 8 pin connector to the 6 pin connector for the NW102mm. If not possible I do have the IAC driver in the pcm so I can go cable if I have to, but I have the whole DBW set up. Does anyone know if this can be done? I want to finish my harness and need to know how to wire this. Thank You!
